Aug 11, 2025 6:22 PM UTC
creo 10.0.0.2.0 - Remove "expand all" from navigation
Hello everyone,
How can I remove the "Expand All" command from the navigation trees?
It’s an extremely annoying icon.
Thank you in advance for your help.
Pavel
KenFarley
Aug 11, 2025 6:42 PM UTC
Model tree info from the support pages:
https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/fundamentals/fundamentals/About_the_Model_Tree_1.html
Seems to indicate that you can't remove such things from the interface.
Unless someone else knows a method, which is unlikely.
RPN
18-Opal
Aug 12, 2025 12:14 PM UTC
I guess the display image is saved on disc, you can try to replace the image by a 1x1 transparent image, if gif or png. This will make it difficult to hit 😵‍💫or a red point only.
If Creo is blaming about the size, I don’t believe that, but you can try to completely remove the image (here you may get a default one), or just a blank image with the same size.
Community Moderator
Sep 30, 2025 9:19 PM UTC
Hi @PS_10957553,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
