Apr 23, 2025 10:37 AM UTC
Creo 11 VBA API get drawing sheet name
Hello Everybody,
Im currently trying to automate the export of dxf files for laser cutting. We just use a seperate sheet in the parts drawing file with a single view of the unfolded sheet part. We always name this sheet "Laser".
Now in VB, I want to search the sheets in the drawing for the one named "Laser" to identify the right sheet to export as dxf, but I cant find any class or variable in the API to get the sheets names. Does someone have an idea for this problem or knows a different way, to savely identify the sheet in VB?
SKerskiAnswer
May 16, 2025 5:31 AM UTC
Thanks for the input Jack. That would be a good idea, because we always name the SimpRep the same. For now, i I managed to create a mapkey, that puts the sheets name into a .txt file with powershell. The only problem is, that the connection is asynchronous and VBA is way faster than powershell. This is the function which gives the name of the currently open sheet as a String:
Function Drw_Blatt_Name(ByRef CreoSession As pfcls.IpfcBaseSession) As String
 Dim fso As New FileSystemObject
 Dim txtFile As Object
 Dim zeile As String
 Dim Versuch As Integer
 Dim maxVersuche As Integer
 Versuch = 0
 maxVersuche = 50 ' z. B. 50 × 100 ms = 5 Sekunden warten
 'Pfad erstellen
 Dim Pfad As String
 Pfad = "C:/temp/Name_Blatt.txt"
 'Blattname in Datei schreiben
 CreoSession.RunMacro ("~ Command `ProCmdDwgPageSetup` ;\")
 CreoSession.RunMacro ("~ Arm `pagesetup` `TblFormats` 2 `0` `sht`;\")
 CreoSession.RunMacro ("~ Select `pagesetup` `TblFormats` 2 `0` `sht`;\")
 CreoSession.RunMacro ("~ Key `pagesetup` `TblFormats` 37945347 `Strg+C`;~ Activate `pagesetup` `OK`;\")
 CreoSession.RunMacro ("@SYSTEMpowershell Get-Clipboard -Format Text > " & Replace(Pfad, "/", "\\") & ";")
 Debug.Print "== Start Drw_Blatt_Name =="
 Debug.Print "Pfad: " & Pfad
 ' Warten, bis Datei vorhanden und nicht leer ist, und sich öffnen lässt
 Do
 If fso.FileExists(Pfad) Then
 If FileLen(Pfad) > 0 Then
 Debug.Print "Datei gefunden und nicht leer. Versuch Nr.: " & Versuch + 1
 On Error Resume Next
 Set txtFile = fso.OpenTextFile(Pfad, 1)
 If Err.Number <> 0 Then Debug.Print "Fehler beim Öffnen: " & Err.Description
 On Error GoTo 0
 If Not txtFile Is Nothing Then
 Debug.Print "Datei erfolgreich geöffnet."
 Exit Do
 Else
 Debug.Print "Datei konnte nicht geöffnet werden (evtl. noch gesperrt?)."
 End If
 Else
 Debug.Print "Datei vorhanden, aber noch leer. Versuch Nr.: " & Versuch + 1
 End If
 Else
 Debug.Print "Datei noch nicht vorhanden. Versuch Nr.: " & Versuch + 1
 End If
 Versuch = Versuch + 1
 If Versuch >= maxVersuche Then
 Debug.Print "Maximale Versuche erreicht – Datei nicht lesbar."
 Drw_Blatt_Name = "FEHLER: Fehler beim Lesen der Datei (nach mehreren Versuchen)."
 Exit Function
 End If
 DoEvents
 Sleep 100 ' 100 ms warten
 Loop
 ' Erste Zeile lesen
 On Error GoTo LesenFehlgeschlagen
 If Not txtFile.AtEndOfStream Then
 zeile = txtFile.ReadLine
 Debug.Print "Erste Zeile gelesen: " & zeile
 Else
 Debug.Print "Datei ist leer."
 End If
 txtFile.Close
 Debug.Print "Datei geschlossen."
 ' Datei löschen mit mehreren Versuchen
 Dim delVersuch As Integer
 For delVersuch = 1 To 10
 fso.DeleteFile Pfad, True
 On Error GoTo 0
 If Not fso.FileExists(Pfad) Then
 Debug.Print "Datei gelöscht."
 Exit For
 End If
 Debug.Print "Löschversuch " & delVersuch & " fehlgeschlagen, warte erneut..."
 Sleep 100
 DoEvents
 Next delVersuch
 Debug.Print "Datei konnte nicht gelöscht werden."
 Drw_Blatt_Name = "FEHLER: Datei konnte nicht gelöscht werden."
 Exit Function
 End If
 ' Erfolgreich
 Drw_Blatt_Name = zeile
 Debug.Print "== Funktion erfolgreich abgeschlossen =="
 Exit Function
LesenFehlgeschlagen:
 Debug.Print "Fehler beim Lesen der Datei: " & Err.Description
 Drw_Blatt_Name = "FEHLER: Fehler beim Lesen der Datei."
End Function
Catalina
Community Manager
Apr 29, 2025 4:39 PM UTC
Hi @SKerski
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. For example:
  • What steps have you taken so far to search for the sheet named "Laser" in the drawing using the Creo VBA API?
  • Have you checked the Creo VBA API documentation for any classes or methods related to drawing sheets?
  • Do you have any existing code snippets that you have tried?
It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Manager
May 15, 2025 2:15 PM UTC
It looks like the VB toolkit does not has access to the licensed methods unfortunately. In the C++ toolkit there is a licensed method wfcWDrawing::GetSheetName that would return the name of the sheet.
You could use IpfcView2D::GetSimpRep to get the SimpRep and the name of that SimpRep to help identify your sheets. Not sure if that would help or not
SKerski10-MarbleAuthorAnswer
 Dim zeile As String
 Versuch = 0
 'Pfad erstellen
 Dim Pfad As String
 Do
 On Error GoTo 0
 Exit Do
 Else
 End If
 Else
 End If
 Else
 End If
 Exit Function
 End If
 DoEvents
 Loop
 ' Erste Zeile lesen
 Else
 End If
 txtFile.Close
 On Error GoTo 0
 Exit For
 End If
 Sleep 100
 DoEvents
 Next delVersuch
 Exit Function
 End If
 ' Erfolgreich
 Exit Function
End Function
