Creo 2.0 Family table verify Using VB.NET
I want to verify the family table in the existing part file using VB.NET. Because of some values are updated even if i use regenerate process table not verified.
Please help me if you anyone know the process / idea.
Balaji.S
2-Explorer
I think it's not possible to verify it through toolkit or VB.Net...You just can get status of instances of family table.
Ketan,
is it possible to run mapkey, which verifies family table instances ?
Martin Hanak
2-Explorer
Not sure...Need to create test plan properly...Simply verification using map key is working fine with below:
mapkey $F2 ~ Command `ProCmdMmFamTab`
mapkey(continued) ~ Activate `ftb_edit_table` `TBVerify`;~ Activate `mdlbrowser` `OK`;\
mapkey(continued) ~ Activate `mdlbrowser` `Cancel`;~ Activate `ftb_edit_table` `OK`;
Note: Family instance in test part on which I checked was having two features one is extrude and one is hole...In first instance, both were visible where as in second one, only extrude was visible.
