Oct 27, 2015 10:48 AM UTC
Creo 2.0 Parametric connection error - VB.NET
Hi Guys,
Currently I am connecting creo 2.0 using the below method-3 only.
But, now i try with connect method (1,2), if i try that method it shows error (pfcExceptions::XToolkitNotFound)
Dim asyncConnection As IpfcAsyncConnection
Dim cAC As CCpfcAsyncConnection
Dim session As IpfcBaseSession
Dim objccpfcconnection As New CCpfcAsyncConnection
Dim exePath, workDir
exePath = "C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.exe"
workDir = "C:\Program Files\PTC\Creo 2.0\Common Files\F000\vbapi\vbapi_examples\models"
Try
                'Method-1
                _objIpfcConnection = objccpfcconnection.Connect(Nothing, Nothing, Nothing, Nothing) - pfcExceptions::XToolkitNotFound
                session = asyncConnection.Session
                session.LoadConfigFile("C:\Users\Public\Documents\config.pro")
                'Method-2
                '_objIpfcConnection = objccpfcconnection.Connect(DBNull.Value, DBNull.Value, DBNull.Value, DBNull.Value)-pfcExceptions::XToolkitNotFound
                'session = asyncConnection.Session
                'session.LoadConfigFile("C:\Users\Public\Documents\config.pro")
                'Method-3
                'cAC = New CCpfcAsyncConnection
                'asyncConnection = cAC.Start(exePath + " -g:no_graphics-i:rpc_input", workDir)
Catch ex As Exception
                MsgBox(ex.Message)
Finally
End Try
I configured creo 2.0 parametric as per guide instructions only.
Please help me where i done mistake.
Balaji.S
2-Explorer
Oct 27, 2015 10:53 AM UTC
Have you set system level Environment variables with short path?
Oct 27, 2015 11:08 AM UTC
Yes ,
I configured Environment variable PRO_COMM_MSG_EXE  and i register vb_api_register.bat also.
2-Explorer
Oct 27, 2015 11:31 AM UTC
Ensure that there is no user level variable with same name and system variable has dos path.
