Feb 10, 2015 6:21 PM UTC
CREO 2 Admin UI
Does anyone know if the way you save to the Admin UI in CREO 2 has changed? Granted it has been a while since I've had to mess with the admin UI, but I recently updated to M110 and it seems to not save the whole UI anymore. Originally the UI was 170kb, and now it is only 29kb. This doesn't make any sense.
Thank you,
Brian Toussaint
Systems Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
Phone: (770) 487-2331 ext. 1216
Fax: (770) 487-3359
www.hoshizaki.com
    Feb 10, 2015 6:32 PM UTC
    I assume you're talking about the ribbon file.
    By default it's only going to save the changes.
    I actually use a special startup script to work on the ribbon file.
    It deletes any .ui files that Creo would see on startup, and then copies the one I have on the network to the startup dir.
    del "<path to=" ribbon=" file=">\creo_parametric_customization.ui"
    echo f|xcopy "<path to=" network=" copy=" of=" ribbon=" file=">\creo_parametric_customization.ui" "%USERPROFILE%\<path to=" creo=" start=" dir=">\creo_parametric_customization.ui" /y /r
    Obviously if it has admin in the name you would have to modify the lines for that, as well as the paths.
    David Haigh
