Sep 2, 2016 7:21 AM UTC
Creo 2 keeps on cashing - Windows 10 - Nvidia quadro 2000M graphics card
Hi
Please could some one help...
Creo 2 crashes every time i open a new model, it basically will open half way then hangs. when i open it a second time it opens up fine, and i can work normally. it will do the same if opening a large drawing file.
i have installed the most current Beta driver from Nvidia (372.54-quadro-grid-desktop-notebook-win10-64bit-international-beta).
i'm currently running Windows 10 64 bit. 16 gigs Ram
System ManufacturerHewlett-Packard
System ModelHP EliteBook 8560w
System Typex64-based PC
System SKUXX058AV
ProcessorIntel(R) Core(TM) i7-2820QM CPU @ 2.30GHz, 2301 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/DateHewlett-Packard 68SVD Ver. F.50, 8/4/2014
SMBIOS Version2.6
NameNVIDIA Quadro 2000M
PNP Device IDPCI\VEN_10DE&DEV_0DDA&SUBSYS_1631103C&REV_A1\4&1B2BA782&0&0008
Adapter TypeQuadro 2000M, NVIDIA compatible
Adapter DescriptionNVIDIA Quadro 2000M
Adapter RAM(2,147,483,648) bytes
Installed Driversnvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um,nvwgf2um
Driver Version21.21.13.7254
Regards
Kevin
Sep 2, 2016 3:18 PM UTC
Creo2 is not supported on Windows10.
Creo3m060 and higher are supported.
kpieterse1-VisitorAuthor
Sep 5, 2016 6:33 AM UTC
Hi Ben
Thank you for your response, what would your recommendation be, rolling back to windows 7? Will there be any support for Creo 2 and Windows 10 in the future?
regards
Kevin
Sep 5, 2016 7:31 AM UTC
Creo Parametric 2.0 M190 and higher is supported on Windows 10 - see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS219828
Suggestion: Add following option at the end of config.pro file temporarily and test Creo behaviour.
graphics win32_gdi
MH
