Creo 3.0 Java toolkit licencing
Do you need an end user runtime licence for Java Toolkit?
for the user that uses the written app, not the developer, just to be clear.
the reason is that i would like to buy (as a private person) a small-ish j-toolkit script that would help me with my work, as my company doesn't want to pay for it (for all users in that case).
Is that lic included by default in a standard creo installation by any chance?
i don't know the actual names, but i work on 2 computers, depending on location. one has also mechanica, UDF... (a lot more features), the other has only the basic "drafing licence"? i would need it only on either one of them.
Hello Robert,
  There are 2 type of license available with Java.
  1. J-Link
  2. Java Object Toolkit
1. J-Link
  • Free License availabe you can use at any basic license of the CREO
  • 50% of the Creo tools can be automate
  • You need to choose this option during creo installation or you can reconfigure your creo
  • Costlier License required
  • Almost 80% of Creo tools can autmate and much more efficient functions than j-link, more tools accesiblity options
  • End users can use this application without License (Application must be unlocked, unlocking required licensed version i.e unlocking system should contain Object toolkit License)
rmcboaty1-VisitorAuthor
Can it be unlocked on another machine or only at the end user? maybe i could persuade the VAR to deploy it once they deploy Creo 3 (or 4)...
By object toolkit licence you mean the Developer licence (mentioned in the above video for example)? because the company definitely doesn't have that.
It can unlocked in developer machine which contains license. after unlocked the application you can use the application at user end.
It depends on the CREO version which the develper license version. If developer has CREO 3.0 license it should be works on all other system CREO 3.0 version.
