Jan 15, 2018 7:26 PM UTC
Creo 3.0 JLink Issue
HI,
I have java application which is currently working in Creo 2.0. Yesterday we had installed Creo 3.0 and checked the application but it is throwing the below error:
Can not read params from db java.lang.SecurityException: Prohibited package name: java.util
I am using the below java version:
C:\>java -version
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot(TM) Client VM (build 25.151-b12, mixed mode, sharing)
Dhimant
Jan 18, 2018 12:27 PM UTC
Hello @dbhensdadia
Check installation of default JRE in Creo 2 and Creo 3
JRE is installed at <Load point>\$PRO_MACHINE_TYPE\obj\JRE\
Check in config.pro option jlink_java_command. If you have this option, than Creo using external JRE. Try to comment this option.
Jan 23, 2018 10:05 PM UTC
This error is gone now I am getting the error while registering the jlink application.
Actually I have the existing jar file which is running fine without any error.
When I tried to rebuild the code inside the net beans and then if I am trying to use the update jar files I am getting the error: Startup of application "xxxx" failed.
I don't know why because the other old binary is running fine but updated one not.
Can you suggest me why it is so?
Dhimant
Jan 24, 2018 8:55 AM UTC
@dbhensdadia When you rebuild the code inside the net beans, ensure in NetBeans setting that you use JDK the same or lower then JRE. Look at next message in this theme.
Jan 23, 2018 10:13 PM UTC
will creo work with java 9?
Jan 24, 2018 8:54 AM UTC
Hi @rmcboaty
Creo 3:
JDK 1.7.0_25
JRE 1.7.0_25 (on media)
JRE 1.8.0_40
Creo 4:
JDK 1.8
JRE 1.8
