Nov 18, 2015 10:44 PM UTC
Creo 3.0 M060 help and also Learning connector
I have the Creo 3.0 M060 help files locally for both parametric and simluate, which I wanted for users who might be traveling and using borrowed licenses.  This must be an issue with Creo 3 and IE10 with annoying activex control issues or just security issue, which I can't change for the users, so I guess I can live with that.  But, I think I must have missed something, because I cannot get learning connector to work.  I click the tab and then nothing happens, it won't expand or anything and I get no error message of any kind.
Nov 19, 2015 1:04 PM UTC
We had an issue with the learning connector icon not working in Creo 2 m120.  It took forever to figure out the issue.  Once we added this "ENV=PRO_LANG=C" to our psf's the learning connector icon worked.  I don't know if it will have the same effect for you but you could give it a try.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS102458&art_lang=en&posno=1&q=ENV%3DPRO_LANG%3DC&source=search
