Jun 27, 2016 1:59 PM UTC
Creo 3 Crashes When Mouse Hovers Over TOOLKIT Routines
We have recently upgraded from Creo 2 to Creo 3, and we have a group of TOOLKIT routines that when run once, Creo will crash when we hover the mouse over any of the routines in the same group.  This only happens when we try to run the routines in this group consecutively.  If we run a routine from a different group, then one of the routines from the problem group, or vice versa, there is no crash.  This problem didn't happen in Creo 2.  Any insight on what is causing this problem would be greatly appreciated.  Thanks!
traceback.log output:
The trace creation timestamp is: Mon Jun 27 09:43:22 16
The executable build timestamp is: Wed Jan 27 02:33:11 16
The datecode is: 2015480
The pro machine type is: x86e_win64
The process ID is: 10428
The traceback type is : CRASH
The logger exit status is: 00003
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 10688.
Main Thread 10688
ERROR: Module information could not be found, GetLastError: 1114 (Address: 0000000000000000)
Mahesh_Sharma
22-Sapphire I
Jul 7, 2016 9:53 PM UTC
Austin,
If you are in active maintenance, submit a case for tech support for toolkit.
