Feb 25, 2026 5:05 AM UTC
Creo 4.0 M120 Drawing Part table associated with master data and work with Drop down action
We have one assembly drawing, and it has 4 components in part table. These 4 components are having multiple part numbers (Likewise family table A123Z_G (generic) A123Z01, A123Z02....A123Z150) Also it has variants like Different pipe size (0.5", 1", 1.5", 2" etc) Different weld type (like fillet, v-groove type, bevel etc.) material (Mild Steel, Stainless steel, Aluminum, Bronze etc.) By considering of these much of parameters and some more, we need to create one master data table in creo drawing which will be working by drop down option and the final output part table should be viewed  on main drawing sheet basis on selection of drop down filters. This is just like a complex excel sheet which has master data, drop down filters and one output tab which shows the exact result based on drop down selection. Do we incorporate the master tables, Drop down tables and Output tables in Creo drawing?
Emeritus
Mar 4, 2026 5:56 AM UTC
Hi @SS_987,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team.
