Creo AFx v. 11.0.4
Creo AFX parameter and relation modifications
I am working on trying to put in custom parameters and relations within the AFX parts. I figured out how to add parameters that are user defined by modifying the AFX  config start_mdl.cfg file, but the relations are not working. I need relation - driven parameters for multiple parameters when any beam profile for AFX is opened so I want them applied globally.
I cannot find the afx_start_model that the start_mdl.cfg in AFX seems to reference for the current relations, and I have tried adding .rel files to reference relations within the start folder and also have tried editing the param_relations folder within the beam profiles without any luck.  I am not sure if it is a file location or syntax error, or if there is something I am missing.
I essentially need to populate the AFX start parts for every beam profile with my own parameters and relations.
Any advice or information would be greatly appreciated.
Catalina
Community Manager
Hi @NE_12819279
Thank you for your post.
Best regards,
Catalina | PTC Community Manager
in folder parts\profiles  create param_relations.txt file and put some relations inside.
That should do the work.
Restart Creo after that and try to create some profiles.
SikiF
