Apr 10, 2019 5:04 AM UTC
Creo crash while activating push button
I use the ProUIListActivateActionSet() function to execute an action.
Once the process is completed when I activate Cancel button, creo crashes.
Kindly throw some light on this
2-Explorer
Apr 10, 2019 12:22 PM UTC
try this once:
void test(char* dialog, char* component, ProAppData data)
ProError err;
ProMdl CurMdl;
ProMdlType CurMdlType;
ProSelection *SelDim;
ProDimension Dim, *MdlItm = &Dim;
ProLine DimText;
int SelCount, i;
wchar_t** suffix = NULL;
err = ProArrayAlloc(2, sizeof(wchar_t *), 1, (ProArray *)&suffix);
suffix[0] = L"@D";
suffix[1] = L"Test";
err = ProMdlCurrentGet(&CurMdl);
if (err == PRO_TK_NO_ERROR)
err = ProMdlTypeGet(CurMdl, &CurMdlType);
if ((err == PRO_TK_NO_ERROR) && (CurMdlType == PRO_MDL_DRAWING))
err = ProSelect("dimension", 1, NULL, NULL, NULL, NULL, &SelDim, &SelCount);
if ((err == PRO_TK_NO_ERROR) && (SelCount != 0))
err = ProSelectionModelitemGet(SelDim[0], MdlItm);
err = ProDimensionTextWstringsSet(MdlItm, suffix);
err = ProArrayFree((ProArray *)&suffix);
2-Explorer
Apr 10, 2019 10:05 AM UTC
AFIK, check with memory management. Nothing to do with API. Try to allocate memory and free the same after usage.
Manjunath1-VisitorAuthor
Apr 10, 2019 11:34 AM UTC
@Ketan_Lalcheta if possible kindly share few examples.
Thanks in advance,
Manjunath S
2-Explorer
Apr 10, 2019 11:38 AM UTC
For example,
char* list is required for an argument to suggested API. You should do it like this
char* list = new char[500]///this should also be used dynamically
post usage of this variable, deallocate the same with delete[] list.
It's difficult to track memory issue if it is really a issue. Share code if possible to have a look once I get time.
