Creo Crashes when changing the dialog
I have a OTK dialog where I use pfsession->Select() for selecting entity from UI. I have button which when presessed, asks user for selection by ->select call. If user launches a new UI or press cancel, creo crashes.
My investigation says, the selection object is leaking. Any help.
I encountered the same problem.
Similar situations occur when I call UIOpenFile() or UISaveFile() function.
output thrown exceptions info: Invalid parameter passed to C runtime function.
I have to use pro toolkit function instead of object toolkit,like  ProSelect()
