Sep 18, 2020 8:03 PM UTC
Creo Distributed Batch and Plot File Extensions
Does anyone know if it is possible to override the plot file extension used by the Creo Distributed Batch utility, and the "PLOT/PRINT to file, GENERIC POSTSCRIPT" Task Type Definition (TTD)?
I have tried everything I can think of, but the output plot files are still created with a .ps file extension.
There exists a PCF setting called plot_name that does exactly what I need (if set to no, then a .plt file extension is used instead of .ps for PostScript).
But I cannot seem to get the Batch file to honor the setting.
The help file implies a PCF file can be used to override relevant plot settings, but it doesn't say say exactly how to accomplish this.
I have tried adding my custom .PCF file to the "Configuration Files" node of the batch group, and have tried specifying my custom .PCF file location in the <PCF_FILE></PCF_FILE> element of the TTD file (found right under the <TKFUNC func="ProPrintExecute"> node).
No luck though.
Thank you for any advice.
Sep 23, 2020 7:50 AM UTC
@TM_7977238 wrote:
So I also added this to my custom .PCF:
plot_label yes
I again added my .PCF file to the Configuration Files node of my batch group.
The resulting plot file did have the new label.
So, that tells me the batch process does honor some settings in my .PCF file, just not the one I really need (i.e. plot_name).
So, it appears the .ps file extension is "hardcoded" inside the Batch utility, at least when using the Generic PostScript TTD.
So, unless there is another way to get around this, I will have to make do with the .ps extension.
I tried to add following line into plot_generic-postscript_use-drawing-size.ttd file
<plot_name>no</plot_name>
Unfortunately out file extension was always .ps.
Note 1: You can ask the same question to PTC Support if you have active support.
Note 2: If it is necessary that the extension be .plt then you can create simple batch file which changes .ps to .plt for all files created using Distributed Batch.
Note 3. You can also create .plt files using standard Creo session running trail file.
I were you I would output .plt file using
Sep 21, 2020 8:35 AM UTC
No luck though.
following information is just my guess ...
  • put plotter option pointing to your custom pcf file into config.pro
  • put path to this config.pro into "Configuration Files" node of the batch group
Sep 22, 2020 2:48 PM UTC
Thank you for the comments.
I added the following to my config.pro file:
plotter PlotFile
That is also the name of the file: PlotFile.pcf
I added the config.pro to the Configuration Files node of the batch group.
File extension still has .ps
It's funny to me that if I do this using the Creo client, the default extension is .plt and I have to add the following to the default postscript.pcf file to get the .ps extension:
plot_name yes.
So, the exact opposite behaviour.
Sep 22, 2020 5:58 PM UTC
plot_label yes
