Creo does not provide any information about Regeneration Status of the model
Hi
1. We develop Design Optimization Software product called as modeFRONTIER,where the product  used by Aerospace Design Optimation and Automobile Design Optimization, Currently working as Jr.Software Engineering
2. We use Creo Parametric of  10.0.0.0 version
3. To regenerate the model we are using Creo Solid::Regenerate API.Complex model requires regeneration status for  multiples Regeneration in order to get the regeneration status of the model,and creo doesnot provide any information about Regenaration Status(whether model is Success/failure) of the model.
We use below three lines of Code for Regeneration
RegenInstructions instr = pfcSolid.RegenInstructions_Create(Boolean.FALSE, null, null);
instr.SetForceRegen(true);
((Solid) model).Regenerate(instr);
We found  that  ProSolidRegenerationstatusGet(). is Pro/toolkit  which is a C Customization tool.However we need OTK java toolkit to determine regeneration Status(wheteher Success/failure of regenration ).
4.We Integrate the Creo Parametric tool with modeFRONTIER .We attempt to  regenerate the model using creo parametric,however after regeneration we are unabl to determine the status of regeneration
5.User can get the satus of regeneration after attempting regeneration of the model.
Only in OTK Java
WRegenerate
void	WRegenerate	( /*optional*/ WRegenInstructions Instrs)
 	Regenerates the model accoding to provided instructions.
This method generates XToolkitRegenerateAgain if the model is too complex to regenerate the first time.
Also you can try to check a regeneration result in action listener
pfcSolid.SolidActionListener.OnAfterRegen
void	OnAfterRegen	(Solid Sld, /*optional*/ Feature StartFeature, boolean WasSuccessful)
 	Provides a notification function called after regenerating a solid.
Manual References:
 Action Listeners: Solid Level Action Listeners, Action Listeners: Solid Level Action Listeners
Parameters:
 Sld
 The solid that was regenerated.
 StartFeature
 The starting feature of the regeneration.
 WasSuccessful
 This is true if the solid regenerated successfully.Otherwise, this is false.
