Mar 9, 2021 4:18 PM UTC
Creo Object Toolkit, WCreateFeature
I'm trying to perform a simple feature creation opertaion using the wfcWSolid::WCreateFeature function in otk.
The feature element tree has been generated using the cxx element tree generator provided by PTC and is meant to create a default coordinate system in a part. Here is the element tree def:
wfcElements_ptr CreateDefaultCoord(pfcModel_ptr Model)
	wfcElements_ptr newElems = new wfcElements();
	wfcElement_ptr newElem;
	CreateElem localElem;
	otkxEnums localEnum;
	CollectionHelpers localCollnHelper;
	/*	 Element id:	386 : PRO_E_FEATURE_TREE	*/
	localElem.CreateCompoundElem(PRO_E_FEATURE_TREE, 0, newElems);
	/*	 Element id:	387 : PRO_E_FEATURE_TYPE	*/
	localElem.CreateIntegerElem(PRO_E_FEATURE_TYPE, 979, 1, newElems);
	/*	 Element id:	1964 : PRO_E_STD_FEATURE_NAME	*/
	localElem.CreateStringElem(PRO_E_STD_FEATURE_NAME, "CS0", 1, newElems);
	/*	 Element id:	2134 : PRO_E_CSYS_ORIGIN_CONSTRS	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_ORIGIN_CONSTRS, 1, newElems);
	/*	 Element id:	2147 : PRO_E_CSYS_OFFSET_TYPE	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_OFFSET_TYPE, 0, 1, newElems);
	/*	 Element id:	3953 : PRO_E_CSYS_ONSURF_TYPE	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ONSURF_TYPE, 0, 1, newElems);
	/*	 Element id:	3954 : PRO_E_CSYS_DIM_CONSTRS	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_DIM_CONSTRS, 1, newElems);
	/*	 Element id:	2137 : PRO_E_CSYS_ORIENTMOVES	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_ORIENTMOVES, 1, newElems);
	/*	 Element id:	3054 : PRO_E_CSYS_NORMAL_TO_SCREEN	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_NORMAL_TO_SCREEN, 0, 1, newElems);
	/*	 Element id:	3050 : PRO_E_CSYS_ORIENT_BY_METHOD	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENT_BY_METHOD, 0, 1, newElems);
	/*	 Element id:	2142 : PRO_E_CSYS_ORIENTSELAXIS1_REF	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_ORIENTSELAXIS1_REF, 1, newElems);
	/*	 Element id:	3167 : PRO_E_CSYS_ORIENTSELAXIS1_REF_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS1_REF_OPT, 0, 1, newElems);
	/*	 Element id:	2143 : PRO_E_CSYS_ORIENTSELAXIS1_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS1_OPT, 0, 1, newElems);
	/*	 Element id:	3052 : PRO_E_CSYS_ORIENTSELAXIS1_FLIP	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS1_FLIP, 0, 1, newElems);
	/*	 Element id:	2144 : PRO_E_CSYS_ORIENTSELAXIS2_REF	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_ORIENTSELAXIS2_REF, 1, newElems);
	/*	 Element id:	3168 : PRO_E_CSYS_ORIENTSELAXIS2_REF_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS2_REF_OPT, 0, 1, newElems);
	/*	 Element id:	2145 : PRO_E_CSYS_ORIENTSELAXIS2_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS2_OPT, 0, 1, newElems);
	/*	 Element id:	3053 : PRO_E_CSYS_ORIENTSELAXIS2_FLIP	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS2_FLIP, 0, 1, newElems);
	/*	 Element id:	4123 : PRO_E_CSYS_ORIENTSELAXIS2_ROT_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS2_ROT_OPT, 0, 1, newElems);
	/*	 Element id:	4124 : PRO_E_CSYS_ORIENTSELAXIS2_ROT	*/
	localElem.CreateDoubleElem(PRO_E_CSYS_ORIENTSELAXIS2_ROT, 0, 1, newElems);
	/*	 Element id:	3051 : PRO_E_CSYS_TYPE_MECH	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_TYPE_MECH, 0, 1, newElems);
	/*	 Element id:	3932 : PRO_E_CSYS_FOLLOW_SRF_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_FOLLOW_SRF_OPT, 0, 1, newElems);
	/*	 Element id:	6133 : PRO_E_CSYS_NAME_DISPLAY_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_NAME_DISPLAY_OPT, 1, 1, newElems);
	/*	 Element id:	6140 : PRO_E_CSYS_DISPLAY_ZOOM_DEP_OPT	*/
	localElem.CreateIntegerElem(PRO_E_CSYS_DISPLAY_ZOOM_DEP_OPT, 0, 1, newElems);
	/*	 Element id:	6139 : PRO_E_CSYS_AXIS_LENGTH	*/
	localElem.CreateDoubleElem(PRO_E_CSYS_AXIS_LENGTH, 0, 1, newElems);
	return (newElems);
Below is the remaining code for creating the element tree and adding it to a part solid. The issue is that this code crashes at the WCreateFeature line:
part = pfcPart::cast(wfcGetObjectFromHandle(wfcProMdlHandle, (void*)pro_part));
pfcModel_ptr model = pfcModel::cast(part);
wfcWSolid_ptr wSolid_ptr = wfcWSolid::cast(model);
#pragma endregion
#pragma region Create Coordinate System
wfcFeatCreateOptions_ptr featOpts = wfcFeatCreateOptions::create();
featOpts->append(wfcFeatCreateOption_nil);
wfcWRegenInstructions_ptr regenInstr = wfcWRegenInstructions::Create();
wfcElements_ptr elements = CreateDefaultCoord(model);
wfcElementTree_ptr elementTree = session->CreateElementTree(elements);
try
	wfcWFeature_ptr feature = wSolid_ptr->WCreateFeature(elementTree, featOpts, regenInstr); <-- Crash
catch (const std::exception& e)
	throw e;
Do you have any idea of why this does not work?
Kind Regards
Daniel
Mar 26, 2021 9:26 AM UTC
Solved this issue by first creating dtm planes and then the coord using the following element tree:
wfcElements_ptr CreateFeature_7(pfcModel_ptr Model)
	localElem.CreateStringElem(PRO_E_STD_FEATURE_NAME, "CS1", 1, newElems);
	/*	 Element id:	2135 : PRO_E_CSYS_ORIGIN_CONSTR	*/
	localElem.CreateCompoundElem(PRO_E_CSYS_ORIGIN_CONSTR, 2, newElems);
	/*	 Element id:	2136 : PRO_E_CSYS_ORIGIN_CONSTR_REF	*/
	localElem.CreateSelectionElem(PRO_E_CSYS_ORIGIN_CONSTR_REF, 3, Model, 1, 2, newElems);
	localElem.CreateSelectionElem(PRO_E_CSYS_ORIGIN_CONSTR_REF, 3, Model, 1, 4, newElems);
	localElem.CreateSelectionElem(PRO_E_CSYS_ORIGIN_CONSTR_REF, 3, Model, 1, 6, newElems);
	localElem.CreateSelectionElem(PRO_E_CSYS_ORIENTSELAXIS1_REF, 1, Model, 1, 2, newElems);
	localElem.CreateSelectionElem(PRO_E_CSYS_ORIENTSELAXIS2_REF, 1, Model, 1, 4, newElems);
	localElem.CreateIntegerElem(PRO_E_CSYS_ORIENTSELAXIS2_OPT, 1, 1, newElems);
	return (newElems);
Thanks to everyone who participate in helping me out!
Regards
Daniel
FV_01
Mar 10, 2021 6:34 PM UTC
this one is questionable - returning a pointer to an object  which supposedly keeps a record of its references, while the pointed object goes out of scope...
this one is also questionable - some kind of a 'helper' instance initiated on stack. Impossible to know if it is doing what it should be doing...
would be a good idea to serialize elementTree  after this call:
 to see if a tree was populated and if it was a valid one.
also, enum's are from pro/toolkit and the code looks like it had been written in otk_cpp style.
Mar 22, 2021 9:01 AM UTC
Your first point might have something to do with it, but my hesitation to believe so is that the code you've mentioned is created by PTC.
Removing
Equals the same error.
A deserialized version looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<PRO_E_FEATURE_TREE AppName="Pro/ENGINEER" AppVersion="6.0"
	 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	 xsi:noNamespaceSchemaLocation="ProTKFeature.xsd" type="compound">
 <PRO_E_FEATURE_TYPE type="int">PRO_FEAT_CSYS</PRO_E_FEATURE_TYPE>
 <PRO_E_STD_FEATURE_NAME type="wstring">CS0</PRO_E_STD_FEATURE_NAME>
 <PRO_E_CSYS_ORIGIN_CONSTRS type="array">
 </PRO_E_CSYS_ORIGIN_CONSTRS>
 <PRO_E_CSYS_OFFSET_TYPE type="int">0</PRO_E_CSYS_OFFSET_TYPE>
 <PRO_E_CSYS_ONSURF_TYPE type="int">0</PRO_E_CSYS_ONSURF_TYPE>
 <PRO_E_CSYS_DIM_CONSTRS type="array">
 </PRO_E_CSYS_DIM_CONSTRS>
 <PRO_E_CSYS_ORIENTMOVES type="array">
 </PRO_E_CSYS_ORIENTMOVES>
 <PRO_E_CSYS_NORMAL_TO_SCREEN type="int">0</PRO_E_CSYS_NORMAL_TO_SCREEN>
 <PRO_E_CSYS_ORIENT_BY_METHOD type="int">0</PRO_E_CSYS_ORIENT_BY_METHOD>
 <PRO_E_CSYS_ORIENTSELAXIS1_REF></PRO_E_CSYS_ORIENTSELAXIS1_REF>
 <PRO_E_CSYS_ORIENTSELAXIS1_REF_OPT type="int">0</PRO_E_CSYS_ORIENTSELAXIS1_REF_OPT>
 <PRO_E_CSYS_ORIENTSELAXIS1_OPT type="int">0</PRO_E_CSYS_ORIENTSELAXIS1_OPT>
 <PRO_E_CSYS_ORIENTSELAXIS1_FLIP type="int">0</PRO_E_CSYS_ORIENTSELAXIS1_FLIP>
 <PRO_E_CSYS_ORIENTSELAXIS2_REF></PRO_E_CSYS_ORIENTSELAXIS2_REF>
 <PRO_E_CSYS_ORIENTSELAXIS2_REF_OPT type="int">0</PRO_E_CSYS_ORIENTSELAXIS2_REF_OPT>
 <PRO_E_CSYS_ORIENTSELAXIS2_OPT type="int">0</PRO_E_CSYS_ORIENTSELAXIS2_OPT>
 <PRO_E_CSYS_ORIENTSELAXIS2_FLIP type="int">0</PRO_E_CSYS_ORIENTSELAXIS2_FLIP>
 <PRO_E_CSYS_ORIENTSELAXIS2_ROT_OPT type="int">0</PRO_E_CSYS_ORIENTSELAXIS2_ROT_OPT>
 <PRO_E_CSYS_ORIENTSELAXIS2_ROT type="double">0.000000</PRO_E_CSYS_ORIENTSELAXIS2_ROT>
 <PRO_E_CSYS_TYPE_MECH type="int">0</PRO_E_CSYS_TYPE_MECH>
 <PRO_E_CSYS_FOLLOW_SRF_OPT type="int">0</PRO_E_CSYS_FOLLOW_SRF_OPT>
 <PRO_E_CSYS_NAME_DISPLAY_OPT type="int">1</PRO_E_CSYS_NAME_DISPLAY_OPT>
 <PRO_E_CSYS_DISPLAY_ZOOM_DEP_OPT type="int">0</PRO_E_CSYS_DISPLAY_ZOOM_DEP_OPT>
 <PRO_E_CSYS_AXIS_LENGTH type="double">0.000000</PRO_E_CSYS_AXIS_LENGTH>
</PRO_E_FEATURE_TREE>
Further details are that the error is of class pfcXToolkitGeneralError.
FV_01
Mar 22, 2021 2:59 PM UTC
PRO_E_CSYS_ORIENTSELAXIS1_REF and PRO_E_CSYS_ORIENTSELAXIS2_REF must have 'selection' type in XML.
The shown XML output had listed them as 'null'
I would check this statement.
This code does not match what the equivalent Pro/Toolkit code would or should be doing behind the scenes.
In Pro/Toolkit those elements should be created with ProElementReferenceSet with ProReference ref = NULL;  (in versions prior to Creo 4 one would need to allocate ref with ProReferenceAlloc(&ref); as well).
HIH.
RPN
18-Opal
Mar 25, 2021 7:36 AM UTC
You try this, with an empty part? I guess this feature requires to be in insert mode (if the part is not empty), and it should be feature #1. And the feature name needs to be unique as well, only to be mentioned.
Mar 25, 2021 9:15 AM UTC
This is done with a empty part, so the feature should be unique.
FV_01
Mar 25, 2021 12:53 PM UTC
write a default csys feature tree into an xml file. Make a datum plane in an empty part and add a default csys after the plane with CreateElementTreeFromXML(...) . Delete the plane.
Daniel_3920531-VisitorAuthorAnswer
	return (newElems);
Regards
Daniel
