Jan 27, 2024 8:47 AM UTC
CREO Parametric - Number of factets on an STL file
I use CREO Parametric 9.0 Student Eddition as a Hobbyist. When creating an STL file (Save as STL) for a 3D printer, I observe that the number of facets on circular srfaces is relatively low.
My question is : How to increase the number of factets, in order to get more precise circular surfaces ?
I foud this article in the CREO support, but it seems to be valid for another software : https://support.ptc.com/help/creo/ced_modeling/r20.5.0.0/fr/index.html#page/ced_modeling/OSDM_Main/Parts_23.html
Is there a limitation of the Student Edition ?
Thanks for your help
tbraxton
tbraxtonAnswer
Jan 27, 2024 1:43 PM UTC
Chord height needs to be minimized to yield the best approximation of model geometry during tessellation. This will result in max number of facets when generating an STL.
Explanation of chord height:
Controlling the Quality of Export (ptc.com)
When exporting do the following:
Select the customize export option
Set the chord height to zero and Creo will minimize it with the lowest possible value for the model.
Set angle control to 1
Jan 27, 2024 8:58 AM UTC
  • set absolute accuracy in model
  • set lower absolute accuracy value in model
Jan 27, 2024 1:01 PM UTC
Changing the absolute accuracy of the model won't change the number of facets.
I have created a video to show you how you can change the way the facets are generated.
The video is made in Creo 10. However, it is the same in other versions of Creo.
You can watch the video through the following link
https://technologiecampusdiepenbeek.be/PTC_Community/STL_facets-Creo_10.mp4
I hope this will help you solve your problem.
Best regards,
     John Bijnens
YHAdesign12-AmethystAuthor
Jan 27, 2024 3:15 PM UTC
Hi John,
Thank you very much for your help ! It works perfectly and I can now specify the accuracy of my STM models.
Thank you for your reactivity 👍
Best regards,
Yves
tbraxton
tbraxton22-Sapphire IIAnswer
Jan 27, 2024 3:07 PM UTC
Thank you so much for your tip abd your reactivity., It works perfectly and now, my STL model are very accurate 🙏
Best regards,
Yves
