Creo ProToolkit API pfcSelection::SetPoint() is not working correctly.
Hi All,
I am working on Creo 5.0.1.0 .
I have observed that the API  pfcSelection:: SetPoint()  is giving wrong results,
Can anyone explain this behavior??
FV_01
FV_01Answer
February 12, 2020
Hi all,
Just a guess.  Could be missing UV parameters ( ProSelectionUVParamSet).
I would try the round-trip test - make a datum tag for a datum plane via UI, then write a code - select a tag, get attachments, get selection object, store all of this, delete the existing tag, create a new one with stored data and the tag should appear at the same location as the original one. If it is not happening - contact tech support
HIH.
what do you mean by wrong behavior?
What is the use case?
What were you expecting?
What was observed?
Thanks for the reply,
So here is the case,
I created the selection object as
pfcSelection_ptr selection = pfcCreateModelItemSelection(item); (Item which is surface)
then I set the desired center point to my selection object,
as selection->SetPoint(point);
then I created an Annotation (Set Datum Tag ) at this attachment(selection  object),
using ProMdlSetdatumtagCreate
But in UI the created SetDatumTag is attached to a different point of selection object,
FV_01
FV_0117-PeridotAnswer
February 12, 2020
Hi all,
HIH.
