Nov 18, 2025 5:07 PM UTC
Creo Toolkit c++ integration with PowerPoint
I want to create a toolkit application that can integrate PowerPoint into Creo. Basically, I would like my application to generate a PowerPoint with information about the assembly and part views and parameter information. Is there any library that could do this integration?
RPN
18-Opal
Nov 19, 2025 9:56 PM UTC
To be honest, more than 30 years ago I told my colleagues stop using the MS suite of software. And I still think that HTML should your first choice. But this is only my 2 cents 😉
If you still decide to go that long and stony way, I wish you the best 🧐 DDE may a starting point.
FV_01
Nov 19, 2025 11:06 PM UTC
try to use 'Office Open XML' and associated SDK's
18-Opal
Nov 20, 2025 3:35 PM UTC
You might take a look at CREOPYSON to use Python to interface Creo and your Office Application?  Depends on the objectives.
