May 13, 2024 2:40 AM UTC
Creo11 and Mapkey pro
We have just installed Creo 11 in our office and have now found the it is stripping the Mapkey from the Config.pro files and placing them in the App data setting folder as a new Mapkey.pro.
This is a big problem for us....
We have multiple start up shortcut that point to different folder that has different Config.pro & search.pro files depending on the task we are working on, and each Mapkey in the config.pro points to a different file location to set the working directory.
I don't have a problem with the Mapkey being placed in a separate file, but I hope we have the option in the config file to point to a different location so we can mange the different options.
Peter
20-Turquoise
Apr 11, 2025 7:02 PM UTC
We just made the switch from Creo Parametric 10.0.8.0 to Creo Parametric 11.0.4.0 last week. I have since learned a couple more unexpected behaviors dealing with personal user mapkeys:
  • Expected: On first launch of Creo Parametric 11.0 it copies the mapkeys from config.pro to <some really hidden path>/.Settings/mapkeys.pro
    • Unexpected: Any conflicting user mapkeys (eg same name) as the system mapkeys.pro are NOT copied into the .Settings/mapkeys.pro file
    • So we then manually edited the .Settings/mapkeys.pro and add the conflicting mapkeys
      • We actually just copied the config.pro, which was mapkeys only, into .Settings/mapkeys.pro
      • So now we have mapkeys that conflict with the system mapkeys.pro
    • Refired up Creo Parametric 11.0
    • Unexpected: The conflicting mapkeys in .Settings/mapkeys.pro are not read.
      • This is different behavior than pre Creo Parametric 11.0 in which the last one read was the winner
      • So it currently is impossible for the user to override mapkeys contained in the system mapkeys.pro when launching Creo Parametric
      • They need to rename these conflicting mapkeys
    • Expected: From the new mapkeys editor doing a manual import of the .Settings/mapkeys.pro overrides any existing mapkey.
So depending on how you want to look at this the inability for the user personal mapkeys to overwrite system mapkeys is either:
  • Yay its about time this happened!
  • or This really sucks and needs to be fixed!
Apr 14, 2025 10:11 AM UTC
from my point of view, the implementation of mapkeys.pro in Creo 11.0 is inappropriate. I do not understand why PTC did not use following paths.
  • Creo_loadpoint\Creo 11.0.x.0\Common Files\text\mapkeys.sup ... these mapkeys could not be overwritten
  • Creo_loadpoint\Creo 11.0.x.0\Common Files\text\mapkeys.pro
  • HOMEDIR\mapkeys.pro
  • STARTDIR\mapkeys.pro
Apr 14, 2025 2:10 PM UTC
Well, PTC did get it 25% right as they do use :
A mapkeys.sup file might work, but in the past, PTC has said do not put mapkeys in the config.sup as it then 'locks' the mapkey command.
I do agree that the other 2 folders would be a lot better placement than the current obscure location.
