Oct 2, 2020 1:34 PM UTC
Creo7.0.1.0 Crashes on executing Toolkit Applications
When I execute any Toolkit application in Drawing mode, and when I am opening corresponding drawing Model from Model Tree, Creo gives Traceback error of Type Crash.
Kindly share your thoughts.
Thanks in advance.
Sagar D.
Oct 2, 2020 4:55 PM UTC
Thanks in advance.
Sagar D.
please report the problem to PTC Support.
Oct 5, 2020 8:27 AM UTC
If you have access to the sources of the toolkit application, then yes, file Toolkit support case. Else if you use the runtime only, then file support ticket to the author of the application.
If you are the developer of the application, you might edit the Traceback and find the exact line where Creo exits.
