Customization of toolbox in creo parametric
I want to implement a customized toolbar in CREO parametric toolkit.
I am using CREO 4.0 , M20. I have added  2 ribbons manually, when I tried to export ,
only  the .ui file is getting saved and  .rbn file is not getting updated .
And also I am not able to load  .rbn file through RibbonDefinitionfileLoad() command.
Does RibbonDefinitionfileLoad() requires CREO Direct license as well ?
2-Explorer
compile error itself? Hope you have included header file
#include <ProRibbon.h>
2-Explorer
I don't think additional license is required. But I am not sure. What is return status of API while loading ribbon file? Is it not_found? What is your .rbn file location?
Sekar11-VisitorAuthor
RibbonDefinitionfileLoad() - Identifier is undefined.
This is what the error i get.
And toolkitribbon.rbn file is saved at C:\Program Files\PTC\Creo 4.0\M020\Common Files\apps\KeyShot\text and C:\Program Files\PTC\Creo 4.0\M020\Common Files\x86e_win64\cma\Plugin\text.
2-Explorer
