Jan 10, 2019 5:51 AM UTC
Customization using jlink or java toolkit
Hello everyone! Just want to know whether we can automate 3d modeling by customizing the creo software using JLink? Or do we need Java toolkit? Can we use eclipse ide or similar to write codes for customizing using Java API or does the Creo Toolkit only supports visual studio?
Regards
Jan 10, 2019 8:34 AM UTC
Hello!
Using J-Link you can create assembles, can get different data from models, but cant create features (sketch, extrude, revolve...). But can place UDF.
Object Java Toolkit a little bit more powerful. But not free.
To write apps, using JAVA, you can use any IDE for JAVA (Eclipse, Netbeans, Idea ....)
C/C++ Toolkit - only Visual Studio. But possible to use Express version.
Hello!
Rohan71-VisitorAuthor
Jan 10, 2019 10:41 AM UTC
You mentioned in your reply that JLink is suited for creating assemblies. You also mentioned about user defined features. Did you mean for the assemblies? Also I want to know how can one define UDFs in JLink and is procedure mentioned in JLink user guide?
Thanks in advance.
Jan 10, 2019 11:38 AM UTC
Assemble models into assembly is possible programmatically in JLink.
J-Link User's Guide - Assemblies and Components
Create new features in model (part or assembly) by placing UDF
J-Link User's Guide - Features - Creating Features from UDFs
