7-Bedrock
Datum attachement location returns (0, 0, 0).
Hello.
I am using Pro/TOOLKIT to connect to a Creo 8.0.5.0 session and to explore the active opened CAD file.
First of all, I need to retrieve the datum tags.
Here there is a skeleton of my program to do that.
ProEngineerConnect() ;
ProMdlCurrentGet() ;
ProMdlNameGet() ;
ProMdlTypeGet() ;
ProSolidSetdatumtagVisit(ProSetDatumTagVisitAction) ;
static ProError ProSetDatumTagVisitAction(ProSetDatumTag* pSetDatumTag, ProError, ProAppData    AppData)
// Obtention du label du datum tag.
  ProSetdatumtagLabelGet() ;
// Recherche des liens vers la géométrie à partir des références.
ProAnnotationReference*                         References(nullptr);
if (ProSetdatumtagReferencesGet(pSetDatumTag, &References) == PRO_TK_NO_ERROR)
     int ReferencesCount(0);
      if (ProArraySizeGet(References, &ReferencesCount) == PRO_TK_NO_ERROR)
         for (int i = 0; i < ReferencesCount; i++)
            switch (References[i].type)
               case PRO_ANNOT_REF_SINGLE:
                  ProSelection Selection(nullptr);
                  ProModelitem ModelItem = { PRO_TYPE_UNUSED, 0, nullptr };
                  if (ProReferenceToSelection(References[i].object.reference, &Selection) == PRO_TK_NO_ERROR &&
                      ProSelectionModelitemGet(Selection, &ModelItem)                     == PRO_TK_NO_ERROR)
                     switch (ModelItem.type)
                        case PRO_AXIS:
                        case PRO_SURFACE:
                                 Pro3dPnt           ptDatumFrameLocation;
                                 ProAnnotationPlane DatumFramePlane;
                                 ProPlanedata       DatumFramePlaneData;
                                 ProSelection       DatumAttachment(nullptr);
                                 Pro3dPnt           ptDatumAttachmentLocation;
                                 if ((ProSetdatumtagTextPointGet(pSetDatumTag, nullptr, nullptr, ptDatumFrameLocation) == PRO_TK_NO_ERROR || ProSetdatumtagTextLocationGet(pSetDatumTag, nullptr, ptDatumFrameLocation) == PRO_TK_NO_ERROR) &&
                                     ProSetdatumtagPlaneGet(pSetDatumTag, &DatumFramePlane)             == PRO_TK_NO_ERROR        &&
                                     ProAnnotationplanePlaneGet(&DatumFramePlane, &DatumFramePlaneData) == PRO_TK_NO_ERROR        &&
                                     ProSetdatumtagAttachmentGet(pSetDatumTag, &DatumAttachment)        == PRO_TK_NO_ERROR        &&
                                     ProSelectionPoint3dGet(DatumAttachment, ptDatumAttachmentLocation) == PRO_TK_NO_ERROR)
BUG ! ->                       ptDatumAttachmentLocation == {0, 0, 0} !!!!
If the datum tag is connected to a geometrical tolerance, the datum tag attachement location returned by Pro/TOOLKIT is null !
For more informations, you can refer to the following case which has been opened for this problem :
https://www.ptc.com/appserver/cs/view/case.jsp?n=16437645
Is it possible to have a correction for this problem ?
Thank you.
Best regards.
