2-Explorer
Jul 14, 2016 9:04 AM UTC
Datum curve through points
How to create Datum curve through points using pro toolkit?
Thanks & Regards
Ketan
Aug 10, 2018 2:30 AM UTC
in tkuse.pdf :
Some other curve types, including Thru Points, From File, and Use Xsec do not
currently use element trees in PTC Creo Parametric, and are therefore not
accessible via PTC Creo Parametric TOOLKIT.
But, you can try the UDF.
i use the UDF method to automatically create curve through points.
