Jun 17, 2010 8:43 AM UTC
Debug & Release for asynch app.
I have created an asynch protoolkit app for WF 5.0 in VS 2008. I have linked following librraies- prodevmd.lib
protkmd.lib ptasyncmd.lib wsock32.lib mpr.lib psapi.lib ws2_32.lib netapi32.lib.
When I build the code using debug option it works fine(though it has some warnings related to protkmd.lib).
When I build using release option it throws following error messages-
Error19 ;error LNK2019: unresolved external symbol _NetRemoteTOD@8 referenced in function _NetRemoteTOD_thunk
After referring to some more posts outside I changed runtime library settings as follows
for debug-
Multi-threaded Debug DLL (/MDd)
for release-
Multi-threaded DLL (/MD)
What I am missing??
Jun 17, 2010 12:09 PM UTC
Rahul,
I believe youneed to use the mt version of the lib files when you switch from debug to release. (ie protkmt.lib, ptasyncmt.lib ).
In Reply to Rahul M.:
for debug-
for release-
What I am missing??
Jun 18, 2010 5:36 AM UTC
I couldn't locate those two libraries in my proe installation.
How could I get them?
Jun 18, 2010 12:51 PM UTC
for 32 bit OS
<wildfileinstalldir>\protoolkit\i486_nt\obj\protkmt.lib
<wildfileinstalldir>\protoolkit\i486_nt\obj\ptasyncmt.lib
<wildfileinstalldir>\prodevelop\i486_nt\obj\prodevmt.lib
for64 bit OS
<wildfileinstalldir>\protoolkit\x86e_win64\obj\protkmt.lib
<wildfileinstalldir>\protoolkit\x86e_win64\obj\ptasyncmt.lib
<wildfileinstalldir>\prodevelop\x86e_win64\obj\prodevmt.lib
if these are not on your system, rerun the installation and select API Toolkits and select Pro Toolkit.
Hope that helps,
for debug-
for release-
What I am missing??
Jun 21, 2010 9:53 AM UTC
I didn't got those files in my WF 5.0 installation,so I approached PTC to get info.As per PTC ‘protkmt.lib’ and ‘protk_dllmt.lib’ files are obsolete and have been removed from ‘obj’ folder"
Now what option I have to remove those linking errors mentioned in 1st post.?
