May 10, 2011 3:07 PM UTC
Default text style in drawing
does anyone know if it is possible to get information about the current text style set in a drawing?
Background:
User can set the current style via "Format / Current Text Style".
Creating a note via Toolkit I think the note's font and size is taken from the settingsof thedrawing options. Font and size can be controlled when creating a note, but for that I first want to know what the current settings are.
(By the way: I hate 2D...)
We are on Wildfire 5 M070,
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
May 10, 2011 6:23 PM UTC
Andreas,
I don't think you can access those properties for the whole drawing but
you can definitely get them for an individual note. ProDtlnoteDataGet()
and subsequent ProDtlnotedata*() APIs can retrieve this information.
Otherwise you might want to check in to config.pro options. Lastly you
could read the file identified by the drawing_setup_file config.pro option
but that effort is not supported by Pro/TOOLKIT. To change those
properties use another setup file and call ProInputFileRead().
PATRICK S WILLIAMS
Information Technology
Mechanical Engr Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (office)
+1 520.446.0244 (pager)
+1 520.545.6399 (fax)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
