18-Opal
Aug 16, 2018 5:04 AM UTC
Delete a datum point with a specific name
How do I delete a datum point with a specific name?
I want to delete the datum points named PNT2 collectively as the following figure.
What if you do not know the ID of the feature?
Let's say you use ProFeatureVisitAction.
The ProFeature API does not have an API to get the name of a feature.
It seems impossible to delete a datum point with a specific name using ProFeatureVisitAction.
Do I know it wrong?
Or any other suggestions?
thanks
Warm Regards,
SeonHo
Aug 16, 2018 6:23 AM UTC
Use "ProFeatureGeomitemVisit" to get geom item
Use following geometry visit function:
ProError GeomVisitFunction(ProGeomitem *p_handle, ProError status, ProAppData app_data)
ProPoint point;
ProGeomitemToPoint(p_handle, &point);
ProVector copoint;
ProPointCoordGet(point, copoint);
return PRO_TK_NO_ERROR;
API "ProPointCoordGet" gives you a vector with x , y and z position.
Aug 16, 2018 5:22 AM UTC
Use ProModelitemNameGet to get feature name.
CHASEONHO18-OpalAuthor
18-Opal
Aug 16, 2018 5:52 AM UTC
Thank you.
I will try your advice.
I would appreciate one more answer.
When using ProSolidFeatVisit (), can I get x, y, z values if the feature type is PRO_FEAT_DATUM_POINT?
If is possible, how do I get it?
ProPoint point;
ProVector copoint;
