Deleting Member of a Pattern Feature
Hello all,
I am trying to get member of a pattern feature and delete them using toolkit.
I am retrieving pattern feature using ProFeaturePatternGet and then using the ProPattern from it ProPatternMemberGet to get a members of that pattern. After getting this member how do I delete this member of pattern so as to have just header of pattern in a feature.
RPN
18-Opal
You have a pattern, only if you have a table, you are able to delete, but take care if this is referenced.
As far I know😉
Sss459812-AmethystAuthor
I just want to have a pattern header or leader and set the table empty. Is it possible?
