Design Automation - How to ?
Hi everyone,
I am looking for help to learn how to make automation in design. I would like to create models that I can easily reuse, simply by modifying some parameters or options. For example a diameter or a length but also whether or not I want to activate this extrusion or that drilling.... etc.
I already know I can automate parameters by using a simple excel sheet. I found this tutorial in video : Creo Parametric Excel Entegrasyonu - YouTube and also this one showing we even don't need to open Creo to modify the parameters (just excel) Video Link : 6428
Sadly I found nothing about how to create options on the design (extrusions, drilling, etc) Actually, only a video that shows it is possible on SolidWorks with KBEWorks. Automatisation de la conception d'un réceptacle avec KBEWorks 2015 - YouTube But KBEWorks seems to run only for Solidworks and I didn't find an equivalent for Creo 3.0....
Could you help me please ?
Thanks in advance for your help !
see http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/#page/pma/fundamentals/About_Pro_PROGRAM.html
and all other documents related to Pro/PROGRAM.
MH
fives1-VisitorAuthor
Thank you for your answer ! I didn't realise that everything about design automation was controlled under Pro/Program.
Best regards,
Fred.
18-Opal
Note : everything is "not" controlled by Pro/PROGRAM ... Pro/PROGRAM serves a purpose but it is not everything.
Always focus on the data-flow - and that includes the process that manages that (taking inputs --> final outputs).
18-Opal
Many ways to get there...
One of the best approaches is to have a "master" model and drawing that responds to input and then does a "save as" for the variation...
IF you love Excel - then you need to look at Nitro-CELL ... and  ... Nitro-PROGRAM
Nitro-PROGRAM is excellent for graphically editing the Pro/PROGRAM logic.
Nitro-CELL is awesome for everything else.
CREOSON is an OpenSource (aka FREE) option if you want to "code" a bit of the process on your own.
Dave
