dimension creation
I am using Creo Parametric - Release 5.0 (connected) Release 5.0 and Datecode5.0.6.0
API ProDimensionCreate is not supported(unable to create dimension) for attachment of type PRO_SILH_EDGE in toolkit API, Also How to select PRO_SILH_EDGE in creo Ui using ProSelect API?? As there is no string available to select PRO_SILH_EDGE.
    Can type string "silhedge" in ProSelect API.
