Nov 21, 2019 9:36 AM UTC
Distributed points at edge or surface
I want to use toolkit to build a system that is average enough to distribute points on selected faces or boundaries.
For example:
import one part or assembly ,
select any face and create a starting point, using this point to fill the entire face evenly。
The density and quantity of points can be adjusted。
How can i do first?
Thanks and Regards
Roger
FV_01
FV_01Answer
Nov 21, 2019 3:52 PM UTC
there is an example in  $PROTOOL_SRC directory showing somewhat similar functionality:
$(PROTOOL_SRC)/protk_appls/pt_examples/pt_extobj/TestExtobj.c
FV_01
FV_0117-PeridotAnswer
CAD_Roger1-VisitorAuthor
Nov 25, 2019 5:48 AM UTC
I don't use UDF.
18-Opal
Nov 21, 2019 4:02 PM UTC
Could this be done using a UDF?
