Dec 10, 2020 2:29 PM UTC
Download secondary content using JLink
There is a method CopyFileToWS where one can specify a model to which a file will be copied as attachement (secondary content). What is a correct way to execute opposite action - to download a secondary content from a model? I can't see any notice in documentation / examples. The method CopyFileFromWS takes a file path, but what is a correct path format to a secondary content file? Or is there another function to achieve this? Thanks in advance.
Jan 27, 2021 12:58 PM UTC
@JurajKosmel wrote:
Or it means I need to write a custom application with the function call?
Yes, it is mean that you mast write DLL with your own custom function witch will call ProFileCopyFromWSDocument() function using C TOOLKIT and then you can call your custom function from J-Link.
Dec 16, 2020 10:43 AM UTC
Not 100% true method, but...
Take a look at "Aliased URL" chapter in the documentation.
Using that set of functions try to construct right path to secondary content file
like this wtws://my_server/my_workspace/intf_file.igs
Some version of Creo required version information additional to extension
test.xml|0.0
or
text.xml|V0.0 (for Creo 2)
where 0.0 - is a PTC_WM_VERSION
Dec 21, 2020 7:34 AM UTC
Thank you for your answer. The aliased URLs are not working for a secondary content files. I've tried it with several path formats, even with version, but no success - I've always got com.ptc.pfc.Implementation.pfcExceptions$XToolkitInvalidFile.
Dec 21, 2020 8:35 AM UTC
From Pro/Toolkit
The function ProFileCopyFromWSDocument() copies a primary or secondary file from the workspace to the specified location on disk.
So, in Jlink it maybe not possible. I'm not found equivalent in Java.
