7-Bedrock
Drawing Dimensions for the Drawing Views
Hi People,
I am working on the creation of dimensions for the Views in the drawing. For that we tried to collect the edges of the solid. Will these edges help me create a dimensions for the view?
Is my approach correct? If it is correct, how to filter the edges which are visible on the drawing screen?
Please suggest the correct and quick approach to achieve drawing dimensioning through code (toolKit C++)...
Thanks & Regards
Abdul Aziz
Emeritus
Hi AA_10646944,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process. This will increase your chances to receive meaningful help from other Community members.
