6-Contributor
Drawing Image files (jpeg) imported into Windchill workspace
We regularly use image files on Creo drawings, we import them from the downloads folder.
When we check in the file in Windchill, it loses the image because it is on the client machine.
Is there a way to import a image file into a workspace so it will check in with the drawing?
pausobAnswer
Not sure if this will help but do you have this config.pro option set to Yes?
save_texture_with_model
pausob19-TanzaniteAnswer
Yes, save_texture_with_model yes saves the picture inside drw file.
KenMeeler6-ContributorAuthor
6-Contributor
