Sep 16, 2010 12:40 PM UTC
.dtl file
Is there a way to read in a drawing dtl file using JLink (sans macro
execution)? I feel like I'm just not seeing it and it's there in one of
the enumeration constants (I also didn't see it in a drawing or other
method).
Any help is most appreciated.
Brian Krieger
Sep 16, 2010 1:20 PM UTC
> method).
I would check out Import() in pfcModel and DWGSetupImportInstructions.
Most likely, you'll need to do something more or less like this:
String fileName = "something.dtl";
DWGSetupImportInstructions inst = pfcModel.DWGSetupImportInstructions_Create();
model.Import(fileName, inst);
Where "model" is the object representing your drawing. The file name should
include the full path to the .dtl file if it's in another folder.
Marc
Marc Mettes
Visit My CAD/PDM AutomationBlog
Or, Subscribe to My CAD/PDM Automation Blog by Email
Sep 16, 2010 7:24 PM UTC
Bingo, Marc! Great answer! Like I said, I figured I was missing it.
Right there in the documentation.
A note about it, though. It appears there is a character limit on the
detail file name used in the import instructions. No biggie as I just
copy the file locally and then get rid of it, but still a limitation.
I'm going to try a couple of other tricks to see if I can get it to
accept a path'd name.
Thanks again, Marc, y'all are great!
BK
