Oct 16, 2019 7:13 AM UTC
Erase memory for ProMdlName
Hi all,
I use code following code to create a Directory using toolkit
err = ProFileMdlnameParse(SelPath00, OutPutPath, MdlName, Ext, rev);
ProWstringToString(DwgName, MdlName);
mkdir(strcat("C:\\temp\\", DwgName))
When i run the application second time, the DwgName is getting appended.
(i.e first time DwgName is 1234, second time it becomes 12341234)
Kindly suggest.
Oct 17, 2019 11:47 AM UTC
Hi, probably  due to the improper use of strcat.
Function strcat has first parameter the pointer to resulting array (this pointer is also returned), second param is string to append.
For the first time you append string to the end of array which begin at some address, second time append next string to this array and so on ... (string array will overlap, exception occurred).
Try to refill the result string (strcpy), at least, e.g.:
char dir [PRO_PATH_SIZE];
strcpy(dir, "C:\\temp\\");
strcat(dir, DwgName);
Btw: You should not use strcat, try something like ProTKSnprintf
PZ
Dec 4, 2019 3:01 PM UTC
At least strcat_s(dir, PRO_PATH_SIZE, DwgName); so you get a crash at "out of allocated memory" and not write over other variables/allocated space inside your memory.
Br,
Eike
RPN
18-Opal
Dec 4, 2019 6:57 PM UTC
You should init a char string
DwgName[0] = '\0';
before using.
