Oct 8, 2014 4:38 PM UTC
Error by imputing values ​​for parameters.
I'm trying to insert some values ​​in two parameters in CREO.
These two parameters are obtained through the values ​​of a JTextField.
This code is in a jbutton. Below is the code:
What is happening is that it is not transferring these values ​​and the application is locking the process, the solution is to end the process.
private void btnInsereParamActionPerformed(java.awt.event.ActionEvent evt) {
try {
Session session = pfcGlobal.GetProESession();
Model model = session.GetCurrentModel();
Parameter paramDescMat = model.GetParam("DESC_MAT");
Parameter paramCodMat = model.GetParam("COD_MAT");
paramDescMat.SetValue(pfcModelItem.CreateStringParamValue(txtDescMP.getText()));
paramCodMat.SetValue(pfcModelItem.CreateDoubleParamValue(Integer.parseInt(txtCodMP.getText())));
} catch (Exception e) {
JOptionPane.showMessageDialog(null, e, "Erro", JOptionPane.WARNING_MESSAGE);
JOptionPane.showMessageDialog(null, "Parametros imputados com sucesso!", "Erro", JOptionPane.INFORMATION_MESSAGE);
Oct 16, 2014 9:33 AM UTC
First of all in this line you tried to put integer to double parameter. This is bad.
Try to comment this line and do test your program again.
Oct 16, 2014 1:40 PM UTC
Thanks Yaroslav Sinitzin for the help!
The problem was that I was using a JPanel. I used a JDialog and it worked perfectly.
I also fixed the problem pointed out by you.
I found the solution here: http://communities.ptc.com/thread/56865
