Jul 11, 2018 11:17 AM UTC
Excel-Analysis with extended Parameters
Hello Community!
I am faced with the following problem in Creo Parametric 4.0. I have an assembly with parameterized parts in it. I want to run an Excel-Analysis on base of the part´s parameters. But the analysis should be placed in the assembly level. Creo just lets me take parameters which are defined in the assembly level. I can´t choose parameters from an assembled part itself.
Does anybody know, if this is possible anyhow? If yes, can you explain how to do?
I attached a picture of the list box I meant.
Jul 12, 2018 4:44 PM UTC
Hello.
Need to map a parameters from a parts to assembly level, using a relations in an assembly. Then you can use this param in Excel. Search how to get a values from part's parameters in the assembly using session ID of the parts.
Jul 13, 2018 6:04 AM UTC
Thanks for your answer, ysinitsyn! Smiley Happy
Do I understand correctly that you mean a relation like this (in the assembly level): Length=Length:4? This was also my temporary solution. But imagine designing a machine with lots of integrated analysis, the number of parameters for these skyrockets due to doublicating part´s parameters. So I am just partly satisfied with this solution.
Is there an opportunity to really take the parameters of the parts (inside the assembly level)?
Jul 13, 2018 6:31 AM UTC
Do you need transfer parameter value from Creo to Excel?
For example, I can add a Dimension from a part to Analysis at assembly level. Maybe you can use a dimensions?
