EXCEL VAB
- Displays the name of the currently active model
- If no model is active, a VBA error message is displayed
- I don't know if the drawing name can be displayed? test it out ^_^
Sub Model_Nanme()
      Dim asynconn As New pfcls.CCpfcAsyncConnection
      Dim conn As pfcls.IpfcAsyncConnection
      Dim session As pfcls.IpfcBaseSession
      Dim Model As pfcls.IpfcModel
      Set conn = asynconn.Connect("", "", ".", 5)
      Set session = conn.session
      Set Model = session.CurrentModel
      Call MsgBox(Model.Filename)
'// Disconnect with Creo
conn.Disconnect (2)
'// Cleanup
Set asynconn = Nothing
Set conn = Nothing
Set session = Nothing
Set Model = Nothing
End Sub
