EXCEL VBA
*** "IpfcAssembly.AssembleByCopy" *** ask for use
This function copies existing parts in assembly and automatically assembles new copied parts.
This is the code i made. there is an error
Dim Solid As IpfcSolid
Dim Assembly As IpfcAssembly
Dim ComponentFeat As IpfcComponentFeat
Dim CreateModelDescriptor As New CCpfcModelDescriptor
Dim ModelDescriptor As IpfcModelDescriptor
'// Load model from "rod_nut.prt" file into Session
Set ModelDescriptor = CreateModelDescriptor.CreateFromFileName("rod_nut.prt")
Set Solid = session.RetrieveModel(ModelDescriptor)
Set Assembly = model
Set ComponentFeat = Assembly.AssembleByCopy("C:\PTC\WORK90\JP100.PRT", Solid, True)
the code that gives the error
please correct
e-mail : korealionkk@gmail.com
Try this one: `Set Assembly = Model`.
cko12-AmethystAuthor
This is the full vba code
Public asynconn As New pfcls.CCpfcAsyncConnection
Public conn As pfcls.IpfcAsyncConnection
Public session As pfcls.IpfcBaseSession
Public model As pfcls.IpfcModel
Sub model_session()
'// Displays the name of the model in the current session
Set conn = asynconn.Connect("", "", ".", 5)
Set session = conn.session
Set model = session.CurrentModel
On Error GoTo E01
If model Is Nothing Then
Err.Raise 5001, , "▶ No models are currently active ◀"
End If
Exit Sub
E01:
MsgBox "Error Number: " & Err.Number & vbNewLine & _
"Error Description: " & Err.Description
Err.Clear
End Sub
Sub componentcopy()
'// current session connection
file_name.model_session
Dim componentFeat As IpfcComponentFeat
Set componentFeat = Assembly.AssembleByCopy("C:\PTC\WORK90\JP100.PRT", Solid, True)
'Cleanup
Set asynconn = Nothing
Set conn = Nothing
Set session = Nothing
Set model = Nothing
End Sub
. The "model" variable holds information about the currently active assembler file
. Assigned "model" information to "Assembly" variable
. I am getting an error in the code above
. "C:\PTC\WORK90\JP100.PRT", I also tried typing "JP100.PRT"
. I also tried changing the file name to lower case.
.  I am not a program development expert. I am making a simple program with the help of chatgtp.
   The creo vba code provided by chatgtp cannot be used. But I'll give you a hint.
.  mapkey cannot be configured with chatgtp  ^_^
please correct
Assembly = CType(model, IpfcAssembly)
ps: some examples ..\Creo x.0.x.0\Common Files\vbapi\vbapi_examples
