Aug 26, 2016 9:41 AM UTC
Export a Tiff file
I'm trying to save a image of a part as a tiff-file, but I can't get it to work.
This is there I came to, it failed on the last line.
I also need to orientate the part in "default orientation" and show in "ho hidden"
Can anyone help?
  private RasterImageExportInstructions getRasterInstructions(RasterType type) throws jxthrowable {
    double rasterHeight = 7.5;
    double rasterWidth = 10.0;
    DotsPerInch dpi = DotsPerInch.RASTERDPI_100;
    RasterDepth depth = RasterDepth.RASTERDEPTH_24;
    RasterImageExportInstructions instructions;
    TIFFImageExportInstructions tiff_instrs = pfcWindow.TIFFImageExportInstructions_Create (rasterHeight, rasterWidth);
    instructions = tiff_instrs;
    return instructions;
      TIFFImageExportInstructions tiff_instrs = pfcWindow.TIFFImageExportInstructions_Create(7.5, 10.0);
      RasterType type = null;
      RasterImageExportInstructions instructions = getRasterInstructions (RasterType.RASTER_TIFF);
      instructions.SetImageDepth(RasterDepth.RASTERDEPTH_8);
      instructions.SetDotsPerInch(DotsPerInch.RASTERDPI_100);
      String sModelName = model.GetFullName() + ".tif";
      MySession.ExportCurrentRasterImage (sModelName, instructions);
Regards
Allan
akok12-AmethystAuthor
Sep 2, 2016 6:41 AM UTC
If I put the last part of my code in a void:
  private static void CreateDTIF(Model model, Session session) throws jxthrowable {
    instructions.SetImageDepth(depth);
    instructions.SetDotsPerInch(dpi);
    session.ExportCurrentRasterImage(sModelName, instructions);
then it works then I call it then I have a part open. But I will like to start the script then I have a drawing, and let the script open the part.
I have tried this:
  private static void ExportToTiff(Session MySession, Model model) throws jxthrowable {
    try {
      String ModelName = model.GetFileName();
      try {
        String PartName = ModelName.substring(0, ModelName.length()-4) + ".prt";
        ModelDescriptor descriptor = pfcModel.ModelDescriptor_CreateFromFileName(PartName);
        com.ptc.pfc.pfcWindow.Window window = MySession.OpenFile(descriptor);
        window.Activate();
        CreateDTIF(window.GetModel(), pfcGlobal.GetProESession());
      } catch (Exception exp) {
        JFrame jFrame = new JFrame();
        jFrame.setAlwaysOnTop(true);
        JOptionPane.showMessageDialog(jFrame, exp.getMessage() + "\n" + exp.toString() + "\n" + "Exception Occured - TIFF 1");
      try {
        String PartName = ModelName.substring(0, ModelName.length()-4) + ".asm";
        window.Activate();
        JOptionPane.showMessageDialog(jFrame, exp.getMessage() + "\n" + exp.toString() + "\n" + "Exception Occured - TIFF 2");
      JOptionPane.showMessageDialog(jFrame, exp.getMessage() + "\n" + exp.toString() + "\n" + "Exception Occured - TIFF 3");
This opens the part, but not export the tiff file.
I think it have some do with the call of "CreateDTIF(window.GetModel(), pfcGlobal.GetProESession());" and using the right session and/or model.
Allan
