Nov 23, 2018 7:37 PM UTC
Export mass report to excel
 might not be the best forum but I'll ask anyway
I'd like to know if there is tool/ method to export the key mass related properties for an .asm? I can save the mass report to a txt file but I am after a way of customising the content to a format that I want i.e. a table like format. .a,csv format spring to mind
One could write a (excel) macro to parse the txt file but it doesn't quite work
Is there a way of creating a BOM table (for a dwg) in the desired table format? for example
Part #, assy level,Mass,CGX,CGY,CGZX,Ixx,Iyy,Izz
I think such BOM can then be exported to a .csv file?
I have heard of ProToolKit but never used
Regards
Nov 30, 2018 5:03 PM UTC
Thanks for the link
It seems that creating a dwg with a table and the parameters available one can get all the data to a .csv. Once opened the data still need a bit of manipulation but at least the data wanted in the 1st place is there.
Nov 26, 2018 12:55 PM UTC
Hello!
The key mass related properties is a parameters of a part PRO_MP_MASS, PRO_MP_IYZ, PRO_MP_IYY.
So, you can use Repeat Region in drawing table.
&asm.mbr.name, &rpt.level, &asm.mbr.PRO_MP_MASS ...
Then you can save this table into CSV
Nov 27, 2018 7:19 AM UTC
Thanks. Will look into this
Chris3
Nov 26, 2018 1:04 PM UTC
I would suggest reading through this thread:
https://community.ptc.com/t5/Customization/Mass-Properties-on-ALL-parts/td-p/2924
RPN
18-Opal
Nov 30, 2018 11:35 AM UTC
You may check the section 'Mass properties - Traverse an assembly ...' here  Scripted as well.
JBlackhole16-PearlAuthorAnswer
Thanks for the link
