Sep 20, 2020 4:54 PM UTC
Export2DOption
I'm trying to export creo drawing to dxf with WebLink application, but I don't know how to use pfcExport2DOption. For PDF there's a documented way how to use options:
var expInstructions = pfcCreate("pfcDXFExportInstructions").Create();
var expInstructions = pfcCreate("pfcPDFExportInstructions").Create();
var pdfOptions = pfcCreate("pfcPDFOptions");
expInstructions.Options = pdfOptions;
But for DXF (pfcExport2DOption) can't find a way to pass options to export instructions.
18-Opal
Sep 21, 2020 11:47 AM UTC
A mapkey may be an option to set your options - assuming they are available via the UI.
dave
pawel_j1-VisitorAuthor
Sep 21, 2020 4:46 PM UTC
Thanks, but I'd expect some programmable solution, like for PDF export. I see there's an CS19626 article about this but unfortunately I don't have subscription.
18-Opal
Sep 22, 2020 11:49 AM UTC
Technically... Mapkeys are a programmable solution... you can parameterize and execute them in your code - they are just not a "native call" to the kernel via a focused API.  Mapkeys, while not elegant - can often fill the gaps in the API that the UI seems to present options for - hence the recommendation.
