Exporting STEP, Specifying a reference csys non interactively
My program involves automated configuration of assemblies.  I am exporting the results as STEP files using ProIntf3DFileWrite.   The 5th argument is reference Csys,  a ProSlection, This argument takes NULL for default csys, but I need a specific csys in my case for future assembly of the step file.    My program runs non-interactively, so there is no one selecting the csys.   I know the name of the Csys and have code where I am successfully finding and obtaining  the handle.    What I cannot seem to figure out is how to convert this csys handle to a Pro Selection.  Any ideas?   Thanks!
msteffkeAnswer
Yes I am converting to geomitem, but I was trying to use ProFeatureSelectionGet.   Not the right function for my situation.   I will try the ProSelectionAlloc that you suggest - fingers crossed!
when you "find" the Csys in your code, do you find it as a ProCsys?
If so, you will need to convert it to a ProGeomitem beforehand.
Something like this:
 ProMdl model; // Get this with your code, or with "ProMdlCurrentGet(&model)";
 ProCsys csys; // Get this with your code somehow
 ProGeomitem csys_geomitem;
 ProCsysToGeomitem((ProSolid)model, csys, &csys_geomitem);
 ProSelection sel_geomitem;
 ProSelectionAlloc(NULL, (ProModelitem*)&csys_geomitem, &sel_geomitem);
Hope this helps!
James Sullivan
msteffke15-MoonstoneAuthorAnswer
