May 22, 2018 7:53 PM UTC
Exporting to STL with JLink
I am using JLink to export all parts in an assembly to STL files. During this, I also create an XML file with the position and rotation of each part in the assembly. (Not all parts export currently but I'm ignoring that for now). I am then importing the parts into another application. This is pretty close to working, but I am running into an issue where things seem kind of "inside out". I obviously can't post images to show what this looks like, but here is the code I'm using to store the position. Can anyone see anything I might be missing that is causing this? When I do the export to STL, I do not specify a coordinate system such as by using:
pfcModel.STLBinaryExportInstructions_Create().SetCsysName()
Here is the code for storing the position information.
public class PositionInAssembly {
 private String partName;
 private String assemblyName;
 private String partType;
 private int id;
 private Point3D origin;
 private Vector3D xAxis;
 private Vector3D yAxis;
 private Vector3D zAxis;
 public PositionInAssembly(String assemblyName, ComponentFeat componentFeat) throws jxthrowable {
 this.assemblyName = assemblyName;
 this.partName = componentFeat.GetModelDescr().GetFileName();
 this.id = componentFeat.GetId();
 this.origin = componentFeat.GetPosition().GetOrigin();
 this.xAxis = componentFeat.GetPosition().GetXAxis();
 this.yAxis = componentFeat.GetPosition().GetYAxis();
 this.zAxis = componentFeat.GetPosition().GetZAxis();
 if (componentFeat.GetModelDescr().GetType() == ModelType.MDL_PART)
 partType = "part";
 else if (componentFeat.GetModelDescr().GetType() == ModelType.MDL_ASSEMBLY)
 partType = "assembly";
 else
 partType = componentFeat.GetModelDescr().GetType().getCipTypeName();
 public String GetXML() {
 String x = "";
 String y = "";
 String z = "";
 String o = "";
 String coordinatesFormat = "%.5f,%.5f,%.5f";
 String parentId = "";
 try {
 x = String.format(coordinatesFormat, xAxis.get(0), xAxis.get(1), xAxis.get(2));
 y = String.format(coordinatesFormat, yAxis.get(0), yAxis.get(1), yAxis.get(2));
 z = String.format(coordinatesFormat, zAxis.get(0), zAxis.get(1), zAxis.get(2));
 o = String.format(coordinatesFormat, origin.get(0), origin.get(1), origin.get(2));
 } catch (com.ptc.cipjava.jxthrowable jxthrowable) {
 jxthrowable.printStackTrace();
 return String.format("<%s name=\"%s\" parent=\"%s\" id=\"%s\">" +
 "<origin>%s</origin><x>%s</x><y>%s</y><z>%s</z></%s>",
 partType, partName.replaceAll("[^a-zA-Z0-9_\\-\\.\\s]", "_"),
 assemblyName.replaceAll("[^a-zA-Z0-9_\\-\\.\\s]", "_"),
 id, o, x, y, z, partType);
Jun 11, 2018 5:26 PM UTC
In case anyone else runs into this, my problem was that +X in Creo was -X in the application I was importing the STLs into. I had to make sure to set the X coordinate to negative as well as the entire X vector (for rotation). I was apparently not properly negating it in one place or another and that was my problem.
nborrerojr.1-VisitorAuthorAnswer
