Oct 14, 2013 2:43 PM UTC
Extracting annotation features data via API
Hi all,
I'm using vb API in order to import a Pro E model into my application, I would like to import also
annotation features such as finish surfaces or geometrical tolerances, however when I acces
the annotation features as follows
Dim annotations As IpfcFeatures = solid.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_ANNOTATION)
For i As Integer = 0 To annotations.Count - 1
Dim note As IpfcFeature = annotations(i)
Dim params As IpfcParameters = note.ListParams()
Dim subItemFaces As IpfcModelItems = note.ListSubItems(EpfcModelItemType.EpfcITEM_SURFACE)
Dim dimensions As IpfcModelItems = note.ListSubItems(EpfcModelItemType.EpfcITEM_DIMENSION)
Next
all of these data are set to nothing.
Is it possible to access those info programatically?
Any help would be greatly appreciated!
Silvia
Sep 5, 2019 5:30 AM UTC
Hi Silvia,
Did you find any solution for above query?
I'm trying to read annotation dimensions from a part model.
