facet selection in protoolkit and point-cloud insertion
Hi and season greetings.
Straight to the point. I am able to acquire a faceted feature with protoolkit but I wonder whether I can get the facets by selecting a portion of the mesh. If I go into the editing phase and select some faces then I can't get the facets in the buffer when I select some facets. The ideal is the selector to return a faceted subset of the original mesh but it seems that it is not doing this or am I wrong.
Also is it a way to insert a point cloud and work with it apart from inserting it as geometry and then suffer from the slow response time?
