Jan 20, 2011 7:49 PM UTC
Facing Compilation issue
Hi all,
I am trying to make one simple Pro/Toolkit appliation using the examples given in the help files.
I am facing issue when there is use of utility functions which are present under pt_utils folder.
Can anyone help me?
I am trying to execute code under pt_examples ( TestGtol.c ) example.
Error: LIST:
main.obj : error LNK2019: unresolved external symbol "enum ProErrors __cdecl ProUtilCollectSolidFeaturesWithFilter(struct sld_part *,enum ProErrors (__cdecl*)(struct pro_model_item *,void *),struct pro_model_item * *)" (?ProUtilCollectSolidFeaturesWithFilter@@YA?AW4ProErrors@@PAUsld_part@@P6A?AW41@PAUpro_model_item@@PAX@ZPAPAU3@@Z) referenced in function "enum ProErrors __cdecl TestMdlGtolShow(void *)" (?TestMdlGtolShow@@YA?AW4ProErrors@@PAX@Z)
main.obj : error LNK2019: unresolved external symbol "struct _iobuf * __cdecl PTApplsUnicodeFopen(char const *,char const *)" (?PTApplsUnicodeFopen@@YAPAU_iobuf@@PBD0@Z) referenced in function "enum ProErrors __cdecl TestGtolInfoSel(void *)" (?TestGtolInfoSel@@YA?AW4ProErrors@@PAX@Z)
main.obj : error LNK2019: unresolved external symbol "void __cdecl ProUtilMsgPrint(char const *,char const *,...)" (?ProUtilMsgPrint@@YAXPBD0ZZ) referenced in function "enum ProErrors __cdecl TestGtolInfoSel(void *)" (?TestGtolInfoSel@@YA?AW4ProErrors@@PAX@Z)
main.obj : error LNK2019: unresolved external symbol "int __cdecl ProUtilYesnoGet(char *)" (?ProUtilYesnoGet@@YAHPAD@Z) referenced in function "enum ProErrors __cdecl TestGtolModify(void *)" (?TestGtolModify@@YA?AW4ProErrors@@PAX@Z)
main.obj : error LNK2019: unresolved external symbol "enum ProErrors __cdecl ProUtilMenuIntValueSelect(struct util_menu_buttons *,int *)" (?ProUtilMenuIntValueSelect@@YA?AW4ProErrors@@PAUutil_menu_buttons@@PAH@Z) referenced in function "int __cdecl TestGtolSelType(void)" (?TestGtolSelType@@YAHXZ)
Thanks in advance.
Mar 26, 2018 2:55 PM UTC
Did you ever figure this out?  I'm having the same issue.
